ChristianWis
May 11, 2022Aspirant
Nighthawk Nighthawk X6 R8000 ac3200 router channels problem
Hello, I have a Nighthawk Nighthawk X6 R8000 ac3200 router. I have wifi interference problems in my apartment, because there are many wifi signals on the same channels as my router. The channe...
ChristianWis
May 12, 2022Aspirant
Can you lower the transmit power in the wireless settings?
I don't know how to do it.
Are you using Smart Connect?
Nope..
What FW do you have loaded on the R8000?
firmware version V1.0.4.76_10.1.82
Thanks for the help Christian
May 12, 2022Guru - Experienced User
I forgot that this model doesn't have any power controls. Otherwise if it did you could turn down the transmit power which would help you with noise and interferences from other near by wifi routers. Makes your routers wifi signal foot print smaller with in the home and less proan to interact with neighboring signals thus less wifi problems with in the home. If you live in a apt complex with lots of other wifi signals you may want to get into a router that has some transmit power controls.
Nope..
