karlmurphy
Apr 03, 2020Aspirant
Nighthawk not visible to Solar Edger inverter
I swapped out an old modem supplied by ISP with a new nighthawk C7500 V2. I just recently noticed that the Solar Edge inverter in the garage hadn't been connected to the WiFi network. I've tri...
- Apr 03, 2020
None of your comments are helpful. You sound like a bot and dont understand anything and you dont seem to be making an effort to understand ether. Just plain unhelpful.
I updatds the firmware on the nighthawk and managed to connect the solar inverter to the wifi network - netgear33.
Problem partially solved.
I had a reconfigure the nighthawk using the genie wizard after updating the firmware on the nighthawk - becuase the firmware update caused a loss of the internet connection into the ethernet lan port 4 on the nighthawk with was showing a red solid light on the top of the nighthawk.
So internet is back up and inverter is connection to the wifi next work.
The problem now is that the house alarm which is connected via ethernet cable to a TPLink switch which is connected by ethernet into the nighthawk and the solar inverter cannot be accessed via mobile apps.
This problem didnt exist before nighthawk so there must be a configuration/secuity setting on nighthawk which control how device on tmy home wifi and wired network "talk" to the internet.
If I solve this I post an update so others can benefit from it.
antinode
Apr 03, 2020Guru
> The old router/modem was a sagemcom gateway fast 3846ac.
"3846ac" or "3864ac"? And it's connected to what, how? Are you
using a DSL connection, or what?
> It might be more helpful if you stuck to an accurate, complete
> description of your equipment, and what's connected to what, [...]
Which parts of "accurate" and "what's connected to what" were
unclear?
> In the garage there is a powered TP link device which I assume is a
> router.
Why would you assume _anything_?
> [...] That's is connected via Ethernet to the Powered TP link.
> [...] (Hint: If a device has different types of Ethernet
> ports, then "connected to device" is not enough detail.)
Still true.
> I think your looking for specifics when everything was working
> perfectly before nighthawk.
I think that I'm unlikely to guess what your problem is without a
reasonably complete description of your gizmos and their configuration.
If you can figure out your problem with less information, then that'd be
fine with me. But I have limited time to waste chasing fundamental
facts which have already been requested.
> It's must be a nighthawk configuration issue.
Could be. But I'm still trying to imagine what a C7500v2 is doing
for you if you've replaced a "sagemcom gateway fast 3846ac" (or 3864ac)
with it.
> [...] Anyway I updated the firmware on the nighthawk [...]
How, exactly, did you accomplish that with a C7500v2?
> [...] I'll try and confirm the model now.
Please do that for _all_ your gizmos, because this whole mess makes
less sense all the time.
karlmurphy
- antinodeApr 03, 2020Guru
> None of your comments are helpful. [...]
Perhaps, but I might be handicapped some by the inaccuracies in your
problem description.Clearly, I don't understand anything, so you'll be happier without
any further distractions from me. Best wishes on your endeavors.- karlmurphyApr 03, 2020Aspirant
Yes sir. Back to your gizmos and imagination.
If I manage to solve the nighthawk issue (and it is a nighthawk issue given that it didnt existing before nighthawk) I'll let you know.
