kbachman32
Sep 08, 2021Follower
nighthawk programing router xr1000
How do i connect by ethernet cable my computer to the router ? i am having problems with the software not working with the ethernet to computer.
Sep 08, 2021Guru - Experienced User
A couple things.
1. you have the XR1000? if so, you're posting in the standard nighthhawk forum and not the pro-gaming forum for that device.
2. What modem/gateway do you have?
3. what firmware is on the router?
4. what actual issue are you having in details? you just put it doesn't connect to your computer via ethernet. have you tried other cables? does wifi work? do other devices work? we need details to be able to help you out.
