Augie1711
Nov 06, 2021Tutor
Nighthawk R000
The webpage at https://xx.xxx.xxx.xx:xxxx/top.html might be temporarily down or it may have moved permanently to a new web address. Is anyone getting this error at the top of the page - I do not hav...
- Nov 07, 2021
Thank you all. I guess the solution is to just wait.
Nov 06, 2021Guru - Experienced User
what router do you have?
firmware on it?
What modem/gateway is it connected to?
Got a screen snip of the error?
Augie1711
Nov 06, 2021Tutor
I have a nighthawk R9000... Ironically, the problem is non existent now. I appreciate your questioning. I did not have a pic. I was focused on resolving an issue and did not know what caused me to lose access to the tabs and advanced settings. It self resolved but have never expierienced this issue. Thank you1
- plemansNov 07, 2021Guru - Experienced User
Eitherway, glad its fixed!
- FURRYe38Nov 07, 2021Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
