Lenamalena21
Aug 29, 2021Initiate
Nighthawk R6080 not connecting to my modem
Hi evertyone! For about a week now, my Nighthawk R6080 router has been having trouble connecting to my internet modem. I've already called mi ISP and there appears to be no issues with the modem. I a...
mnmacd
Sep 18, 2021Guide
Having the ssame issue as the OP.. Was a solution ever found?
Sep 18, 2021Guru - Experienced User
mnmacd If you have the exact same issue, you can read through what we went over and try them. when the OP is reliable posting back and stops after solutions are given, usually it means it fixed the problem. (the OP should mark it as solved to confirm but it rarely happens)
If that doesn't help fix your issue, please start your own thread.
