jhqiv
Apr 26, 2021Tutor
Nighthawk R6080 randomly shuts down
My wireless router is only 6 months old and suddenly it just shuts down randomly and then come back on its own. Firmware is current. I have used reset button and disconnected power numerous times. Do...
Apr 26, 2021Guru - Experienced User
How do you know it shuts down?
Do the led's all go off and then power back on?
What firmware are you actually running?
What modem is it connected to?
have you tried reinstalling or downgrading the firmware? Sometimes the latest isn't the greatest.
Have you tried replacing the power supply? (i wouldn't buy one) If you had a matching or simlar (has to have same voltage and polarity but can have more amps) you could try that.
jhqiv
Apr 26, 2021Tutor
I know it shuts down because all the lights on the box are off. I unplug it and then reconnect and the l8ghts come back on. It then goes off again in an hour or so. Never the same amount of time. Nothing has changed with the connections to the power or my cable internet supplier. The firmware is current. 8 an using the Nighthawk app to stay current and there is no option to go to an older version. I have requested a replacement. It is less then one year old.
- plemansApr 26, 2021Guru - Experienced User
jhqiv wrote:
I know it shuts down because all the lights on the box are off. I unplug it and then reconnect and the l8ghts come back on.----Try a different outlet as well as check the power supply. It then goes off again in an hour or so. Never the same amount of time. Nothing has changed with the connections to the power or my cable internet supplier.---doesn't mean something hasn't went bad, whether that be the router, gateway, etc. Its why we ask. The firmware is current.----Not always a good thing, also why we ask. what version are you on? 8 an using the Nighthawk app to stay current and there is no option to go to an older version.---You follow the manual firmware update process through the brower to downgrade firmware. I have requested a replacement.----So if you've already gone through support and they're replacing it, why post on here? It is less then one year old.- jhqivApr 26, 2021TutorI posted in here before I contacted support. I contacted support because I didn't receive a response in here. Thanks for your suggestions.
