Bingman111
Dec 31, 2020Guide
Nighthawk R6230 bricked after firmware upgrade
After performing the firmware upgrade (104, I believe) the router shut off and never rebooted. The picture shows how the router looks. After 30/30/30 reset the two lights I circled will alternate flas...
NMRPFlash01
Jun 07, 2021Aspirant
Use NMRPFlash
Download the program nmrpflash, install npcap and then set a static IP. Once setup with a static up and plugged into the router, run the nmrp with the correct network device (nmrpflash.exe -L to list) and power the router. The router will boot off the LAN port you are plugged into:
See attachment
https://github.com/jclehner/nmrpflash
https://github.com/jclehner/nmrpflash/releases
Then you can use whatever FW you want to put back on the router. The older versions still have bridged mode but newer versions have removed that option.
