solarsurf
Oct 08, 2020Aspirant
Nighthawk R6400 - Redirect outgoing IP address
I have a data logger on a local area network that sends data to a remote server for long-term storage. The company that provides the server and storage service is terminating support and will no long...
- Oct 09, 2020
> Some might. [...]
Note that some non-Netgear routers (or non-Netgear firmware for
Netgear routers) might allow the user to specify name-address data in
potentially useful ways for your situation. I seem to recall (dimly)
questions in these forums from users who sought how-to guidance for a
Netgear router to do what they had been doing on some other vendor's
models. More market research might reveal a router which has a more
helpful feature set.
antinode
Oct 09, 2020Guru
> [...] I was hoping that a typical router would keep a small domain
> name table within its local memory. [...]
Some might. Even some Netgear models might. I've never seen a
Netgear model which allows the user to fiddle with anything of that
sort. Hence the suggestion of a local DNS server (or "hosts" file),
with which you _can_ fiddle. (A Raspberry Pi, for example.)
This kind of redirection stuff is not impossible, but getting a
consumer-grade Netgear router to do it might be tough.
The DNS processing in a typical Netgear router does intercept names
like "routerlogin.net", and deals with them internally, so it's not as
if the whole concept is foreign, but it's not intended to be
user-configurable. (And I know approximately nothing about the
details.)
If your R6400[vX?] allows you to enable Telnet access into it, then
you might be able to find a way poke something into it to get the
desired effect, but something like a firmware update, or even a restart,
might clean out any such modification. (And Netgear has crippled that
(undocumented) feature in recent R7000 firmware, too, so relying on it
carries its own dangers.) Everything's complicated.
antinode
Oct 09, 2020Guru
> Some might. [...]
- solarsurfOct 09, 2020Aspirant
Many thanks for that information antinode. I learned a lot.
Best regards to you,
