Dinkica32
Jan 26, 2021Aspirant
Nighthawk R6400v2 dropping WiFi
AC1750 smart WiFi router model R6400v2 Router keeps dropping the WiFi signal both 5 and 2.4 ghz. Wired seems to be working fine and only impacts WiFi. Have restarted both router and modem several tim...
michaelkenward
Jan 27, 2021Guru - Experienced User
What do the wifi LEDS show when this happens?
Dinkica32 wrote:
Per the system it’s tuning the latest version of software.
I assume that means running on the latest firmware, but who knows?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
- Dinkica32Jan 27, 2021Aspirant
Te LEDs are either orange or gone completly for both 5 and 2.4 Ghz. We have one LAN line connected to it and that one remains orange and works fine.
@Dinkica32 wrote:
Per the system it’s tuning the latest version of software.michaelkenward I assume that means running on the latest firmware, but who knows?
Yes firmware sorry. It was upgraded yesterday so whatever the latest one is as of 1/26/21. I will have to get the number. We had to disconnect the router for now and switch to our old one in order to get wifi back in the house.
Yes we have a modem before the router. It is the Cisco Model DPC3208 and yes it does have LAN ports you can plug directly into it.
Hope this helps.
- michaelkenwardJan 27, 2021Guru - Experienced User
Dinkica32 wrote:
The LEDs are either orange or gone completly for both 5 and 2.4 Ghz. We have one LAN line connected to it and that one remains orange and works fine.
That doesn't seem right. According to the manual, Wifi LEDs are supposed be be white.
The LAN port also should be white for 1000 Mbps Ethernet. Orange is for 10-100 Mbps.
The problem there is that "the latest" that you get with the on-line update may not be the tatest if you visit the support pages. Firmware can appear there before it gets onto the update server.
The device I found for that has only one Ethernet port on the back. The other ports are for telephones. In that case it would be a simple modem and not a modem/router.
- SDH71Jan 27, 2021AspirantMine has done the exact same thing. I’ve unplugged and rebooted multiple times today. I decided to use my other router a Belkin for now and I am having no problems. I’m pretty sure it’s the firmware after reading multiple problems about this dated today
