edx15
Oct 11, 2023Aspirant
Nighthawk R6700 and Cox modem
Hello Netgear Community: This is my initial post to this forum. Until 0800 hrs, MST, I had an active internet connection via Cox cable, using a cox internet router & a D-Link DIR-615 router. ...
- Oct 11, 2023
Dear Netgear community, esp Kitsap:
Thanks for the reply.
I apologize for not providing sufficient information.
I decided to contact Netgear support. I spoke with Anish, who said that he was in Southern India.
He solved my problem. Using the Netgear Genie interface, we put the Nighthawk in Router mode.
We disabled the existing router.
$99.99 well spent.
Sincerely,
edx15
Kitsap
Oct 11, 2023Master
It would help to know a little bit about what you are trying to do.
Your new CGM4141 is a combination modem and Wi-Fi router device and your R6700 is a couple of generations out of date Wi-Fi router. The R6700 could be configured as a wired access point to provide Wi-Fi in another area of your home. Alternatively, you could enable the bridge mode on your CGM4141, connect the R6700 downstream and let it perform the routing and Wi-Fi function.
You do not want both devices trying to perform routing functions on the same network. With bridge mode on your CGM4141 enabled, both the routing function and Wi-Fi are disabled.
- edx15Oct 11, 2023Aspirant
$99.99 well spent.
Sincerely,
edx15
- KitsapOct 11, 2023Master
edx15 wrote:Dear Netgear community, esp Kitsap:
$99.99 well spent.
Sincerely,
edx15
Glad you got it working to your satisfaction. Recommend you save a backup configuration file in case your would need to reset your R6700 some time in the future.
Please mark this thread as resolved so others may benefit from your experience.
- michaelkenwardOct 12, 2023Guru - Experienced User
$99.99 well spent.
A few minutes here, and you might have got that answer for nothing.
Kitsap actually gave the answer to your problem.
It is a classic case of "two-router" (NAT) syndrome.
I chip in only to point out that if this was the official Netgear "Premium Support" service
NETGEAR ProSupport for Home | NETGEAR
it says "After 1 year, auto-renews annually". You should be ready for that auto-renew gotcha.
- edx15Oct 12, 2023Aspirant
Dear MichaelKenWard & Kit something:
Thanks for the teeny tiny gotcha notice.
I called netgear & requested to opt out of the auto renewal.
The problem was as your correctly identified. I wanted to void dueling routers.
Sincerely,
edx15
