edx15
Oct 11, 2023Aspirant
Nighthawk R6700 and Cox modem
Hello Netgear Community: This is my initial post to this forum. Until 0800 hrs, MST, I had an active internet connection via Cox cable, using a cox internet router & a D-Link DIR-615 router. ...
- Oct 11, 2023
Dear Netgear community, esp Kitsap:
Thanks for the reply.
I apologize for not providing sufficient information.
I decided to contact Netgear support. I spoke with Anish, who said that he was in Southern India.
He solved my problem. Using the Netgear Genie interface, we put the Nighthawk in Router mode.
We disabled the existing router.
$99.99 well spent.
Sincerely,
edx15
edx15
$99.99 well spent.
Sincerely,
edx15
Kitsap
Oct 11, 2023Master
edx15 wrote:Dear Netgear community, esp Kitsap:
$99.99 well spent.
Sincerely,
edx15
Glad you got it working to your satisfaction. Recommend you save a backup configuration file in case your would need to reset your R6700 some time in the future.
Please mark this thread as resolved so others may benefit from your experience.
