btv_94's avatar
btv_94
Guide
Jun 20, 2020
Nighthawk R6700 frequent wifi disconnects after firmware V1.0.2.8 update.
I've been experiencing frequent wifi disconnects on all devices. All wired connection is still working.
Each time happens I have to recycle power both modem and router and everything is fine for about a day.
Any advice and suggestion would be appreciated.
The setup:
AC1750 Wifi Router (not a version number. AC1750)
Modem  Arris surfboard sb6183
  • If you update firmware and have issues, a reasonable first step is to factory reset and reinstall. See if it helps.
    If it doesn't, then you can downgrade the firmware. maybe that one has issues with your device.
  • plemans's avatar
    • btv_94's avatar
      btv_94
      Guide
      Thanks plemans for reply,
      I'll do reset and reinstall as suggested and will report back.
      • btv_94's avatar
        btv_94
        Guide
        I didn't reset the router since my last post. The router was working fine for 10 days, then it got disconnected. This time both wired and wifi didn't work through the router. I called spectrum tech support thinking that maybe the modem is the cause, but it's not the case. With single ethernet cable from modem to my desktop pc, the internet is working and was told by spectrum tech support that the problem is the router.
        So i did the factory reset and still nothing. Not sure if the new update cause the hardware to fail or the hardware itself just died.
        Working from home, must have internet connection. Went out and get new router within 3 hours and everything is working again.
