bvon's avatar
bvon
Nighthawk R6700 usb network drive problems
Got a Nighthawk R6700 firmware V1.0.2.26_10.0.61. I'm trying to connect a WD elements 2TB network hard drive to it and access via local network. When I access via my MacBook pro everything is fine. But when I look at it through the network, I have 2 drives instead of one like Q_Drive and R_Drive. I didn't create these and not sure where they came from or why there are two when I formatted the hard drive to just have one drive. Also, several folders and files are renamed. It will change the name from something like African Playground - Putumayo to something like AN40E0~9. This happens for several folders. It will also change some files from something like Mudali Thuma - The Balladeers / Anura Jayasingha.flac to an unix executable file called MGU1DJ~B.
I'm not sure why these strange things are happening nor how to resolve them.
Any ideas would be great.
Thanks
No RepliesBe the first to reply
