Namo
Nov 02, 2023Initiate
Nighthawk R6700 v3 router not relaying wifi signal
My R6700v3 router is wifi stopped sending wifi signal there are onlt first 2 leds lighted. I logged into my Nighthawk phone app but no problem shown there. Tried power cycling but Wifi signal doesn't...
- Nov 02, 2023The LEDs for wifi are also button you can press to enable or disable the wifi. Did you try it?
Namo
Problem got resolved shortly when I found about a wifi signal start/stop button.
Thanks a lot for your assistance.
Nov 02, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
