jny243
Jun 18, 2020Aspirant
Nighthawk R6700 V3 wireless repeater question
Reading the instructions, it says to connect the router being converrted to AP by ethernet to the existing main router. There is no instruction for the next step - I assume I can then disconnect the ...
- Jun 24, 2020
Hi jny243,
Good day!Welcome to NETGEAR Community!
Regarding your concern, if you set up the R6700v3 router as an Access point, it needs to be connected via ethernet cable to the main router. This router doesn't support Repeating function and almost all of our routers doesn't support this feature anymore. If you want to extend the wireless signal of your main router, we would recommend getting a wireless extenders. You may check this link https://www.netgear.com/home/products/networking/wifi-range-extenders/.
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
olympos1625
Jun 24, 2020NETGEAR Employee Retired
Hi jny243,
Good day!
Oliver
Community Team
