drew_s
Jul 24, 2018Aspirant
Nighthawk R6700v2 - No internet from modem - Gets IP for a few seconds then WAN link goes down
Hello everyone, I've read every(!) post about the R6700 and no internet connection. I've tried all the suggestions with no avail. So hopefully someone can help me with my specific setup.
TL;DR...
- Jul 25, 2018
If your older router works fine, Probably your R6700 is bad. I would go to a local store with NG routers and a good refund policy and check out out for a few days.
Also need to check your network adapter card as well. Make sure it's able to connect to a router, modem and a switch at 1000mb and not 100Mb.
drew_s
Thanks for the reply. The Suddenlink tech tried a router/modem combo and that worked. I tried an old simple Netgear router (don't remember the model) and it didn't work.
Jul 24, 2018Guru - Experienced User
When you say SuddenLink tech tried a modem/router combo, mean he connect this combo to the Arris 6183?
When connecting your PC directly to the 6183, is your network adapter card connecting at 100Mb or 1000Mb?
Disable any PC security software and browser add-ons temporarily...
- drew_sJul 24, 2018Aspirant
No I meant he removed the Arris 6183 and put a new Arris modem/router combo in it's place. So the end result was:
Internet cable > new Arris modem/router > PC
- FURRYe38Jul 24, 2018Guru - Experienced User
You didn't get a chance to have him hook up the R6700 to the modem router combo did you?
Seems like if you have tried the R6700 and a other older router and both don't work, possible that the 6183 maybe bad on it's WAN port...
To confirm that your other routers are working, you could take these routers to a friend, nieghbor or families place to see if they work at a different location. Or go get a different modem and test with your NG router...
Yes, we tried this and I believe it didn't work. It seemed like their router/modem combo didn't like having another router plugged into.
Well wouldn't the fact that I get internet when going directly from PC to the modem rule this out? We also tried three different modems (the modem only model). He did say these modems were acting up and he's replaced a lot of them. But it seems unlikely three are bad? Although I'm just now remembering that the router/modem combo was brand new and all three modem-only's were refurbs.
Good idea.
Yeah I can try the NG again with the latest modem and see what happens.
Thanks for the help!
