drew_s
Jul 24, 2018Aspirant
Nighthawk R6700v2 - No internet from modem - Gets IP for a few seconds then WAN link goes down
Hello everyone, I've read every(!) post about the R6700 and no internet connection. I've tried all the suggestions with no avail. So hopefully someone can help me with my specific setup.
TL;DR...
- Jul 25, 2018
If your older router works fine, Probably your R6700 is bad. I would go to a local store with NG routers and a good refund policy and check out out for a few days.
Also need to check your network adapter card as well. Make sure it's able to connect to a router, modem and a switch at 1000mb and not 100Mb.
Jul 24, 2018Guru - Experienced User
So when this PC is connected to the modem directly, your only seeing 100Mb? Happen to have another PC to test this with?
Possible that the WAN port on the modem isn't giving 1000mb speeds.
drew_s
Correct.
Yes I have a MacBook Pro I can* test with. I'll do that as well when I get home.
I know with at least two of the modems (a modem-only, and a modem/router comb) I was only getting 100mb which leads me to believe there is something wrong on my PC. Also, the modem/router combo was putting out 400mb/s through the WiFi, but my computer was only getting 100mb/s.
Edit: cant to can
