drew_s's avatar
drew_s
Nighthawk R6700v2 - No internet from modem - Gets IP for a few seconds then WAN link goes down
Hello everyone, I've read every(!) post about the R6700 and no internet connection. I've tried all the suggestions with no avail. So hopefully someone can help me with my specific setup.    TL;DR...
  • FURRYe38's avatar
    Jul 25, 2018
    If your older router works fine, Probably your R6700 is bad.  I would go to a local store with NG routers and a good refund policy and check out out for a few days.
    Also need to check your network adapter card as well. Make sure it's able to connect to a router, modem and a switch at 1000mb and not 100Mb.
