3Aly12
Sep 25, 2019Aspirant
Nighthawk R6700V2 Blocking sites
Hi, I have a Nighthawk R6700V2 and am noticing that it is blocking my Macbook and iPhone (when on wifi) from accessing sites like gamestop.com or finishline.com. I never had this issue in the past a...
- Oct 07, 2019
again, if you can't access it when you're directly connected to your modem and your router isn't connected at all, how is it going to be blocking? so its either modem or isp thats blocking if the router isn't hooked up.
3Aly12
I also wanted to show the screenshot from gamestop.com as well. Thanks!
- plemansSep 26, 2019Guru - Experienced User
What modem are you using? (brand and model number)
Are there any other routers on your network?
Usually when I see issues like this its because there's a combo device or another router prior to the device you're using.
also what firmware is on your router?
If there's no other routers/combo devices on your network, you could try changing your dns provider to either googles 8.8.8.8 or 8.8.4.4 or cloudfare 1.1.1.1
- 3Aly12Sep 26, 2019AspirantHi Plemans. I am using a modem provided by my ISP (the forced us to use it); not sure what the model number is but it is called Home Grid Forum and it’s a Gn.h coax Gigabit Ethernet Bridge.
I did try using Google’s DNS, Open DNS, and Cloudfare but to no avail.
The router states it has the most up to date firmware V1.2.0.62_1.0.1.
I do have an old Apple Time Capsule but it’s in bridge mode and just use it for backup. Thanks!- plemansSep 27, 2019Guru - Experienced User
There's serval different home grid forum devices that have gn.h. Many of them have a router integrated with them. If so, that'd put you in a double nat situation. I can't say for certain thats whats going on without a model number for your device.
https://kb.netgear.com/30186/What-is-Double-NAT
https://www.pcworld.com/article/3175739/how-to-identify-and-resolve-double-nat-problems.html
