3Aly12
Sep 25, 2019Aspirant
Nighthawk R6700V2 Blocking sites
Hi, I have a Nighthawk R6700V2 and am noticing that it is blocking my Macbook and iPhone (when on wifi) from accessing sites like gamestop.com or finishline.com. I never had this issue in the past a...
- Oct 07, 2019
again, if you can't access it when you're directly connected to your modem and your router isn't connected at all, how is it going to be blocking? so its either modem or isp thats blocking if the router isn't hooked up.
3Aly12
Oct 06, 2019Aspirant
Yes, my ISP company is investigating. It’s not my computer because I tried using the 1.1.1.1 app on my iPhone and it would not work. However using tunnel bear both hardwired directly to the modem or wirelessly to router, I was able to access the sites. I also tried using my windows work laptop and it would not work either ; so that eliminates the computer being the problem. So it has to be either the router or modem right? The fact I couldn’t access it via my iPhone is still leaning me towards the router.
Oct 07, 2019Guru - Experienced User
- 3Aly12Oct 15, 2019Aspirant
Well the IPS was able to have gamestop.com work for me. Still working on finishline.com. Thanks for your help!
