stottad87
May 22, 2017Aspirant
nighthawk r6700v2 losing internet connection periodically
Periodically i will lose internet connection to the router. when the pc is plugged directly to the modem theres is no issue. but whenever i lose connection through the router i turn the router off, u...
- Mar 29, 2018
Hi Mkoish and Bob_Ross,
Please check this firmware and see if the same problem.
https://kb.netgear.com/000054437/R6700v2-Firmware-Version-1-2-0-16
ElaineM
May 22, 2017NETGEAR Employee Retired
Welcome to the community, stottad87
Do you notice if the power light goes off on the unit when it loses the connection?
Did you try reinstalling the firmware of the router?
If not, I suggest that you do that first then factory reset the unit.
