stottad87
May 22, 2017Aspirant
nighthawk r6700v2 losing internet connection periodically
Periodically i will lose internet connection to the router. when the pc is plugged directly to the modem theres is no issue. but whenever i lose connection through the router i turn the router off, u...
- Mar 29, 2018
Hi Mkoish and Bob_Ross,
Please check this firmware and see if the same problem.
https://kb.netgear.com/000054437/R6700v2-Firmware-Version-1-2-0-16
stottad87
May 24, 2017Aspirant
I had to factory reset the router when i initially setup the router because no internet was coming through the router, was onm phone with netgear support for 45mins trying all kinds of methods before it started working, and the firmware has been reinstalled. I will try to factory reset again but will it take me another 45mins and try different methods before it will connect again?
stottad87
theres got to be some reason why the router wont let internet through bc the only way i get internet through router when it stops is by unplugging and plugging in power to modem and turning power on and off with router? is it something to do with the MAC address?
