stottad87
May 22, 2017Aspirant
nighthawk r6700v2 losing internet connection periodically
Periodically i will lose internet connection to the router. when the pc is plugged directly to the modem theres is no issue. but whenever i lose connection through the router i turn the router off, u...
- Mar 29, 2018
Hi Mkoish and Bob_Ross,
Please check this firmware and see if the same problem.
https://kb.netgear.com/000054437/R6700v2-Firmware-Version-1-2-0-16
eligia
Jun 19, 2017Aspirant
I'm on week #2 of owning the nighthawk r6700v2 / V1.1.0.38_1.0.1 and I'm having to reboot multiple times per day.
The internet connection slowly degrades for all devices until all traffic ceases and reset is required, I've resorted to resetting using the admin console to avoid walking into the other room.
I noticed several 1 star reviews on amazon describing similar issues.
- ElaineMJun 21, 2017NETGEAR Employee Retired
Will you guys experience the issue if you downgrade the firmware?
Did you try MAC Spoofing?
MAC spoofing will be unnecessary if you're on DSL connection.
- MargaretBJun 21, 2017Aspirant
My unit has behaved well since I reseated my yellow ehternet cable to the modem. Recently, we moved and I experienced one more lockup just after I was plugging in more ethernet cables to the router. I think the WAN socket is really sensitive to cable movement.
