stottad87
May 22, 2017Aspirant
nighthawk r6700v2 losing internet connection periodically
Periodically i will lose internet connection to the router. when the pc is plugged directly to the modem theres is no issue. but whenever i lose connection through the router i turn the router off, u...
- Mar 29, 2018
Hi Mkoish and Bob_Ross,
Please check this firmware and see if the same problem.
https://kb.netgear.com/000054437/R6700v2-Firmware-Version-1-2-0-16
clee1978
Jun 26, 2017Aspirant
I am experiencing the same issues with this device as well. I am using the device as an Access Point. I have tried all firmware updates available and performed factory resets using the 30/30/30 method. I have currently found that firmware V1.1.0.34_1.0.1 is the most stable; however, I still experience disconnects with my late 2014 Macbook Pro, two Samsung Galaxy S7 phones, Samsung Galaxy Tab, Kindle Fire HD, Amazon Echo, a Windows 10 laptop, and a Windows 7 laptop. I never had these issues with my ASUS RT-N66U Dark Knight. Wireless connections for all of these devices using the ASUS were always stable. I really would like for this device to function properly because it is extremely fast when it does work. I suppose my question is that has anyone found a firmware version that is working for them, and does Netgear plan to address this issue in a new firmware update soon? Thanks in advance for the help, and I hope Netgear gets this resolved soon!
V/r
clee1978
eligia
Jun 29, 2017Aspirant
V1.1.0.34_1.0.1
MAC Spoofing enabled.
1. If I wire directly into my cable modem, and visit speedtest.net I get ~25Mbps (by pass router completely.) GOOD
2. If I wire directly into the router, and visit speedtest.net I get ~25Mbps (No WiFi) GOOD
3. If I connect to 2.4 GHz and visit speedtest.net I get ~5Mbps
4. If I connect to 5GHz and visit speedtest.net I get ~8Mbps
Over WiFi the speeds are consistently slow and slowly degrade until all connections eventually begin failing. Frustration is growing in my househould. The WiFi download speeds are quite slow, evrn when direclty beside the router with varying devices. (MacBook, iOS/Android Tablets, Phones).
If there is a way for me to turn up logging and provide them, let me know. I'm willing to work with a dev if that will help identify and resolve this issue.
I'm close to returning the router.
- eligiaJul 02, 2017Aspirant
I noticed when WiFi connected devices begin failing to reach the internet, DNS requests fail with timeout
]$ dig google.ca ; <<>> DiG 9.8.3-P1 <<>> google.com ;; global options: +cmd ;; connection timed out; no servers could be reached
While in this state I can successfully ping the DNS servers listed in the Internet Port section of the admin console:
$ ping 206.248.154.170 PING 206.248.154.170 (206.248.154.170): 56 data bytes 64 bytes from 206.248.154.170: icmp_seq=0 ttl=60 time=97.866 ms 64 bytes from 206.248.154.170: icmp_seq=1 ttl=60 time=16.569 ms 64 bytes from 206.248.154.170: icmp_seq=2 ttl=60 time=27.254 ms 64 bytes from 206.248.154.170: icmp_seq=3 ttl=60 time=28.252 ms 64 bytes from 206.248.154.170: icmp_seq=4 ttl=60 time=152.658 ms 64 bytes from 206.248.154.170: icmp_seq=5 ttl=60 time=47.626 ms 64 bytes from 206.248.154.170: icmp_seq=6 ttl=60 time=92.136 ms
After I sign into the admin console and hit reboot,
$ dig google.ca ; <<>> DiG 9.8.3-P1 <<>> google.ca ;; global options: +cmd ;; Got answer: ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 35461 ;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 0 ;; QUESTION SECTION: ;google.ca. IN A ;; ANSWER SECTION: google.ca. 103 IN A 172.217.0.227 ;; Query time: 112 msec ;; SERVER: 192.168.1.1#53(192.168.1.1) ;; WHEN: Sun Jul 2 19:29:13 2017 ;; MSG SIZE rcvd: 43
Internet connectivity is now restored .
- TianJul 04, 2017Aspirant
I wish I could return it...
- KidsmakeyoucrazJul 12, 2017Tutor
I'll chime in. I'm having the same problems with my month old Nighthawk R6700v2. Sometimes it will go days and work fine, sometimes I have to reset it 2-3 times in a day. When mine drops, sometimes it's only wifi devices, but usually it's both wifi and hard wired. I contacted support and was given a list of steps to take that I knew wouldn't fix anything, but I've been around long enough to know you have to follow the script. Factory reset / change channels (why this would affect wired connections is beyond me...) change fragmentation settings. It locked up 2 hours after making the recommended changes. I'm awaiting their reply now.
If I hadn't thrown the box away I'd send it back.
- eligiaJul 12, 2017Aspirant
Writing this message for the second time as my post failed because the router required a reboot. Pretty frustrating...
Kidsmakeyoucraz wrote:Sometimes it will go days and work fine, sometimes I have to reset it 2-3 times in a day.
I have noticed similar, sometimes 2 days will pass without a reset, but then 2 or 3 resets in a day are quite common.
I am still curious whether the routers DNS service is related, as I've noticed when I'm unable to open a new connection e.g. visit http://www.google.com in a browser on my tablet or macbook, because name resolution fails my childrens active netflix streaming sessions seem to continue unaffected.
ElaineM is the cause of these issues unknown? Is this issue currently under active investigation? I would really like know if relief is coming or should simply return this router for one that works. I repeat I'm willing to work with your dev team to resolve, I'm quite proficient and provide any required information, logs.
- KidsmakeyoucrazJul 13, 2017Tutor
eligia wrote:I have noticed similar, sometimes 2 days will pass without a reset, but then 2 or 3 resets in a day are quite common.
When mine dies, it dies. Any active streams, online gaming etc all go down. I'm not even able to ping my NAS via it's IP from the PC and they are both plugged directly into the router. I've also noticed that both the 2.4 and 5ghz wireless lights turn off when it locks up. What's really strange is sometimes even though the lights are off, my wireless devices still see the router, but it won't pass traffic. It's very frustrating. The wireless coverage and speeds of the router are amazing when it works. I'm about ready to dust off my linksys wrt-54g. It might not be fast by todays standards, but it's rock solid.
- clee1978Jul 15, 2017Aspirant
This is exactly the problem that I had. I gave up on this device and returned it for a competitor's product. I have had no issues with my new device. Honestly, I wanted this device to work. As others have said, when this device works, it is extremely fast, and the wireless coverage is excellent. I have a friend who purchased the exact same model, and has had no issues, even using the latest firmware; thus, I am wondering if there are some of these devices that simply have hardware issues that cannot be alleviated via firmware. I hope for those who do not have the opportunity to return this device receive a resolution from Netgear soon. Best of luck to everyone in this thread and many thanks for sharing your experiences.
V/r
cle1978
- ElaineMJul 21, 2017NETGEAR Employee Retired
I apologize for any inconvenience.
You may contact support and get a free hardware check to verify if it's faulty or not.
- Lbeagley79Jul 21, 2017Aspirant
Hi Elaine,
Appreciate the response, but my router too is just outside the warranty period. Purchased March 28th, 2017 via Amazon. Ended up ordering a different manufacturer's router and performance is now rock solid. Guess I'll just hang on to the netgear r6700v2 in case the performance issues get resolved.
- eligiaJul 27, 2017Aspirant
ElaineM wrote:I apologize for any inconvenience.
I came here to say this, I spoke with Netgear L2 Support and shared screen shots of slow connection speed, test results and constant loss of internet connections. The support rep suggested proceeding with an RMA and the replacement R7000 is currently Out for Delivery.
