stottad87
May 22, 2017Aspirant
nighthawk r6700v2 losing internet connection periodically
Periodically i will lose internet connection to the router. when the pc is plugged directly to the modem theres is no issue. but whenever i lose connection through the router i turn the router off, u...
- Mar 29, 2018
Hi Mkoish and Bob_Ross,
Please check this firmware and see if the same problem.
https://kb.netgear.com/000054437/R6700v2-Firmware-Version-1-2-0-16
Lbeagley79
Jul 15, 2017Aspirant
About 2 months ago I had posted about firmware version 1.1.0.34 fixing many of the connection issues I was having with this router. Performance with that firmware and the latest version (1.1.0.38) is definitely better, but not solved unfortunately. It runs solid for a few days, then I start getting dropped connections again. Will continue watching this thread and hope for a fix soon because the hardware is great when it is working correctly.
