stottad87
May 22, 2017Aspirant
nighthawk r6700v2 losing internet connection periodically
Periodically i will lose internet connection to the router. when the pc is plugged directly to the modem theres is no issue. but whenever i lose connection through the router i turn the router off, u...
- Mar 29, 2018
Hi Mkoish and Bob_Ross,
Please check this firmware and see if the same problem.
https://kb.netgear.com/000054437/R6700v2-Firmware-Version-1-2-0-16
Lbeagley79
Jul 28, 2017Aspirant
Hi annirun,
Yes those are exactly the same symptoms I experienced. Switching routers fixed the issue as well in my case which points to something faulty in the 6700v2.
Lbeagley79
Elaine,
Could use your help getting an RMA issued. I called customer support twice today, both times waiting over 30 minutes without an answer. I have a case # ready, but don't plan on spending more time waiting for an answer. Would be happy to send you the case # and contact info directly if you can help.
