stottad87
May 22, 2017Aspirant
nighthawk r6700v2 losing internet connection periodically
Periodically i will lose internet connection to the router. when the pc is plugged directly to the modem theres is no issue. but whenever i lose connection through the router i turn the router off, u...
- Mar 29, 2018
Hi Mkoish and Bob_Ross,
Please check this firmware and see if the same problem.
https://kb.netgear.com/000054437/R6700v2-Firmware-Version-1-2-0-16
Janitorial
Jul 30, 2017Aspirant
Taken when no connectivity problems presentTaken after DNS_Probe_Finished_Bad_Config errors
I too had a similar problem shortly after purchasing this router. After the initial setup I was able to successfully connect devices via wifi and wired for ~3 days with no issues. Then at an (apparantly) random time of day all devices on the network would lose the ability to browse the internet via Chrome, Firefox, IE, etc. and would come up with a "DNS_Probe_Finished_Bad_Config" error when trying to reach a web address (e.g. www.google.com). However, the websites could still be accessed using the IP addresses, lending to the hypothesis that the issue is with where the router is looking to for the DNS servers. Additionally, the devices all showed they were still connected to the internet (internet never dropped), for example, a youtube video would not get interrupted unless we navigated away from it. We then went into the router settings and configured it to specifically use set DNS IPs (8.8.8.8 and 8.8.4.4) rather than automatically using what the ISP gave, to test whether the issue had to do with the router receiving the IPs from the ISP. This didn't resolve the issue. Power-cycling the router, as others have said, did resolve the issue and all devices were again able to browse the internet until the issue appeared again. After power-cycling, we inputted the ipconfig /all command in cmd to confirm the router was indeed using the correct DNS server IPs (Capture1). We then left the window open and when the DNS errors began again, we ran ipconfig /all and it showed the router as using its own IP as the DNS server IP: 192.168.1.1 (Capture2). This leads us to believe the router is experiencing some problem with the DHCP service that causes the DNS server to be incorrectly updated/switched.
