stottad87
May 22, 2017Aspirant
nighthawk r6700v2 losing internet connection periodically
Periodically i will lose internet connection to the router. when the pc is plugged directly to the modem theres is no issue. but whenever i lose connection through the router i turn the router off, u...
- Mar 29, 2018
Hi Mkoish and Bob_Ross,
Please check this firmware and see if the same problem.
https://kb.netgear.com/000054437/R6700v2-Firmware-Version-1-2-0-16
ElaineM
Aug 01, 2017NETGEAR Employee Retired
MargaretB I suggest that you submit one then I'll make a follow-up with support.
By the way, how long have you had the router? Make sure as well that you register it.
MargaretB
Aug 01, 2017Aspirant
I will submit one later today. I have had the router for two months. It was registered the day I installed it.
