stottad87
May 22, 2017Aspirant
nighthawk r6700v2 losing internet connection periodically
Periodically i will lose internet connection to the router. when the pc is plugged directly to the modem theres is no issue. but whenever i lose connection through the router i turn the router off, u...
- Mar 29, 2018
Hi Mkoish and Bob_Ross,
Please check this firmware and see if the same problem.
https://kb.netgear.com/000054437/R6700v2-Firmware-Version-1-2-0-16
mwpra
Aug 15, 2017Aspirant
I had the exact same problem listed here - router dropped internet connection every night. I also saw the DNS_PROBE_FINISHED_BAD_CONFIG error. Restarting the router was a temporary solution.
Props to whoever made the link to the Amcrest camera static IP config, because I had that exact setup.
Changing my camera to use both static IP and a static DNS server seems to have solved my problem.
