stottad87
May 22, 2017Aspirant
nighthawk r6700v2 losing internet connection periodically
Periodically i will lose internet connection to the router. when the pc is plugged directly to the modem theres is no issue. but whenever i lose connection through the router i turn the router off, u...
- Mar 29, 2018
Hi Mkoish and Bob_Ross,
Please check this firmware and see if the same problem.
https://kb.netgear.com/000054437/R6700v2-Firmware-Version-1-2-0-16
blooma
Aug 15, 2017Aspirant
Hello, I have this router for about a month now. It is working great in the first couple of weeks, but recently I have been having disconnects everyday and even on multiple times a day. I am using the latest firmware version V1.1.0.42_1.0.1. I am not sure if the latest firmware is causing this but some people in this thread said that backing out to earlier firmware does not help.
I have just tried switching the router's MAC address to my laptop's so I will see if this fixes the problem or not.
If this does not work either, netgear really needs to recall this product and either fixing it, or give full refund. My 30 days return windows has just expired a few days ago, if I knew a lot of people having this problem I would have returned it.
bgtees
Exact same issue, and I have an Amcrest IP cam (the 720p model). Going to try and assign it a static IP/DNS and hopefully that will fix the issue. I've been running that camera for 18 months with my previous router (Asus RT-N66U) and never had a single DNS issue. This is gointg to make me very unlikely to buy Netgear next time due to the amount of time I have had to spend troubleshooting this issue.
