stottad87
May 22, 2017Aspirant
nighthawk r6700v2 losing internet connection periodically
Periodically i will lose internet connection to the router. when the pc is plugged directly to the modem theres is no issue. but whenever i lose connection through the router i turn the router off, u...
- Mar 29, 2018
Hi Mkoish and Bob_Ross,
Please check this firmware and see if the same problem.
https://kb.netgear.com/000054437/R6700v2-Firmware-Version-1-2-0-16
VincentDu
Oct 21, 2017Aspirant
So it's not just me... My R6700V2 drops the connection periodically as well. On good days, it drops only every other hour. On bad days, it drops like every 10 minutes. I have to connect to a VPN for work purpose. Every time the connection drops, I have to reset the VPN. It is way beyond annoying. Tried to call support to return it, and the wait time for a rep is always more than an hour. No time for that. Netgeat, you can do better...
- Bob_RossNov 04, 2017Aspirant
I also have this issue ever since I bought this router in July 2017. If this really is a hardware issue I would love to RMA and swap this out. If this can be solved with a firmware update then I'll gladly do that.
I've upgraded the firmware 3 times and factory reset it afterwards and that still hasn't resolved this issue. I wish I would have known about this before purchasing the router.
