stottad87
May 22, 2017Aspirant
nighthawk r6700v2 losing internet connection periodically
Periodically i will lose internet connection to the router. when the pc is plugged directly to the modem theres is no issue. but whenever i lose connection through the router i turn the router off, u...
- Mar 29, 2018
Hi Mkoish and Bob_Ross,
Please check this firmware and see if the same problem.
https://kb.netgear.com/000054437/R6700v2-Firmware-Version-1-2-0-16
cryptonium_us
Dec 30, 2017Aspirant
Yes the latest firmware worked for a while. Today i had to reboot at least 10 times to watch a single movie. Netgear still has not fixed the issue. Try to fill a ticket to get a replacement unit but not sure they will contact me since i am after the 90 days period. Last time i buy netgear.
Gonna give them a couple of days then i will order a new router. Enough is enough. Although the latest firmware description mentionned it was fixing the connectivity issue, it did nothing. Total piece of junk, incompetent engineering.
fa28
Call netgear and request a RMA # to return the one you have and get another. The hardware has a 1 year warranty; the 90 days is for free phone support. There is a place somewhere on thier site to request an RMA and also a phone #. They will try and talk you out of returning it but if you tried everything you should demand to return it for a replacement.
You will have to pay for return shipping, which was $10 for me and I used my old router while I waited for the new one. You can have them send a new one first then return the bad one, but I think shipping is more and you need to give a CC# so they know you will return it.
