stottad87
May 22, 2017Aspirant
nighthawk r6700v2 losing internet connection periodically
Periodically i will lose internet connection to the router. when the pc is plugged directly to the modem theres is no issue. but whenever i lose connection through the router i turn the router off, u...
- Mar 29, 2018
Hi Mkoish and Bob_Ross,
Please check this firmware and see if the same problem.
https://kb.netgear.com/000054437/R6700v2-Firmware-Version-1-2-0-16
JamesGL
Mar 29, 2018NETGEAR Employee Retired
JamesGL
Apr 01, 2018NETGEAR Employee Retired
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- Bob_RossApr 16, 2018Aspirant
So I flashed to the most recent firmware that was pushed to my router and on the website, and the problems actually came back. I can't believe I was suckered into updating my firmware. I have tried to reset my router and now everytime I turn on my desktop the router poops out and I have to power cycle BOTH my modem and router for the internet to come back up.
I can't believe this problem wasn't fixed and that it actually caused my router to drop connection all the time. I honestly can't recommend this router to anyone or Netgear at this point.
So disappointed....
- Jamesmoon2Apr 17, 2018Aspirant
I am experiencing the same type of connectivity issues described herein and I would like assistance. My router drops connectivity intermittently and I am unable to connect even via a hard wired desktop. I am running Firmware Version V1.2.0.16_1.0.1. Power cycling the router fixes the issue, but the issue reproduces itself.
My Case Number is 30012881
- ostromarkApr 19, 2018Star
Do you have any Amcrest IP cameras (or similar devices) on your home network? If so, disconnect them for a while and see if your router stays online. If that's your problem... you can configure the cameras to use your ISP DNS addresses instead of the netgear router IP and that should fix it.
