Fiskars
Dec 05, 2021Aspirant
Nighthawk R6700V2 repeating function
Nighthawk R6700V2 Router Firmware V1.2.0.88_1.0.1 The knowledge base article refers to the screen captured in the attached as having a Repeating Mode 7. Select Advanced Setup > Router/AP/Bri...
michaelkenward
Dec 06, 2021Guru - Experienced User
Fiskars wrote:
There is ethernet between the routers.
With a wired link between two routers the most obvious solution is to put the second one in AP mode.
More reliable, easier to set up and faster.
