RESmith
Jun 15, 2021Aspirant
Nighthawk R6700v2 Router connection via mobile hotspot
My question is: Can I connect my Nighthawk R6700v2 Router to the internet by way of a mobile hotspot? Thanks!
RESmith
My mobile hotspot is my iPhone 11. I don't currently have an ethernet connecting cable to the iPhone 11, that I'm aware of. Do you know if such is available to buy? Am I understanding correctly that a physical ethernet connecting cable - from the mobile hotspot to the Nighthawk router - is the only way to connect the two?
Jun 15, 2021Guru - Experienced User
the R6700 doesn't have a repeater/extender mode that I'm aware of.
So you'd need to hardwire into it
- michaelkenwardJun 16, 2021Guru - Experienced User
The R6700V2 listed in the subject does have a "WiFi bridge" mode. (Page 185 in the manual.) Whether or not it will work with a mobile hotspot is another matter.
