Tanz64's avatar
Tanz64
Tutor
Aug 29, 2020
Nighthawk r6700v2 slow ethernet
My Nighthawk R6700V2 seems to be throttling throughput speeds. There was a big storm last night, and during it, there were two loud *pops* and the internet went down, but I still had power. I was abl...
  • plemans's avatar
    Aug 29, 2020
    A couple things to try.
    1. replace the ethernet cable.
    2. reload the firmware on it. If the storm corrupted something in the firmware, a reset doesn't fix it. So reinstall the firmware, factory reset the router, and then manually reinstall it.
    3. If it only fried the 1 port (if it did), theres an option in the debug menu to mirror the wan port to lan port one.
    you go to the routers ip address   192.***.*.*/debug.htm     check off the mirror wan port option.
    If it was only that port that got fried, it might work.
