LADM
Dec 03, 2023Aspirant
Nighthawk R6700v2
After losing power, my router never reconnect – any suggestions as to updating settings or issues?
LADM
Dec 04, 2023Aspirant
Thank you so much for the informative information. I’ve taken screenshots of my router details from the NIGHTHAWK app if I could send them to you so you could look them over. Also, I took a video of my LED lights on the front of my router, showing you what is blinking. I have also checked, there are no updates available at this current time. Please advise ..
michaelkenward
Dec 04, 2023Guru - Experienced User
"Blinking" LEDs are usually a sign that there is traffic on that bit of the router. The manual explains that.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Troubleshoot With the LEDs.
Please read my previous messages again.
I have suggested various things that you could try.
How did you check?
Sadly "no updates available" is not a reliable or helpful indicator when troubleshooting. It depends on how you check the firmware version. The app is not good for that.
People turn up here all the time mistakenly making the "latest firmware" claim.
The on-board check for new firmware is unreliable. It can miss updates, especially when you are a long way behind the latest. It can also be a while before updates hit the automated update servers.
Look at the Router Information page in the screenshot you provided.
- LADMDec 11, 2023AspirantRouter is definitely working better with your suggestions, but, would like to ask you about a new – updated router suggestion from you?? Please advise with recommendations. THANX‼️
- michaelkenwardDec 11, 2023Guru - Experienced User
LADM wrote:
Router is definitely working better with your suggestions, but, would like to ask you about a new – updated router suggestion from you?? Please advise with recommendations. THANX‼️It depends in what you want to do, the size of your building and the depth of your pockets.
Try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
