Chasaroo
Mar 01, 2022Tutor
Nighthawk R6700v3 AC1750 ReadyShare printer USB Control Center not loading correctly
First, I downloaded the ReadyShare Printer setup_v1.36.zip and extracted. Got three files: ......v1.36 shortcut, .....exe file, and ..... release notes. Second, While running the .exe file that was...
- Mar 03, 2022
The printer is always connected to the desktop, but I don't leave it on. Use Windows share will be my next step, buying a wireless printer or get a commercial program. Let's close this discussion and give it up for awhile? Thanks again, Chasaroo
Mar 02, 2022Guru - Experienced User
I just downloaded and installed it on my windows pc without issues.
Have you tried uninstalling and reinstalling it again?
Or even tried on a different pc?
also check your security settings/setup on your pc. A lot of times you get stuff blocked from install from windows or other security programs.
Its a challenge because its troubleshooting the pc versus the router.
