Chasaroo
Mar 01, 2022Tutor
Nighthawk R6700v3 AC1750 ReadyShare printer USB Control Center not loading correctly
First, I downloaded the ReadyShare Printer setup_v1.36.zip and extracted. Got three files: ......v1.36 shortcut, .....exe file, and ..... release notes. Second, While running the .exe file that was...
- Mar 03, 2022
The printer is always connected to the desktop, but I don't leave it on. Use Windows share will be my next step, buying a wireless printer or get a commercial program. Let's close this discussion and give it up for awhile? Thanks again, Chasaroo
Mar 02, 2022Guru - Experienced User
what printer do you have?
Chasaroo
Mar 02, 2022Tutor
I haven't tried to hookup my ESP 3250 Kodak USB printer to router because I haven't been able to get readyshare loaded correctly. Today, after deleting everything connected to readyshare, did a restart, turned off my firewall, my McAfee Total protection, readyshare just repeated what it did before? Maybe you will have to make a tour of my computer. Don't know what else to try? Thanks again, Chasaroo
- plemansMar 03, 2022Guru - Experienced User
If you have a computer that is always on, you could connect the printer to that and share it on the windows network.
Not sure why you can't get the readyshare print utility to install.
- ChasarooMar 03, 2022Tutor
- ChasarooMar 09, 2022Tutor
Couldn't find where I could accept solution?
