Chasaroo
Mar 02, 2022Tutor
Nighthawk R6700v3 AC1750 ReadyShare printer USB Control Center not loading correctly
First, I downloaded the ReadyShare Printer setup_v1.36.zip and extracted. Got three files: ......v1.36 shortcut, .....exe file, and ..... release notes. Second, While running the .exe file that was...
- Mar 04, 2022
The printer is always connected to the desktop, but I don't leave it on. Use Windows share will be my next step, buying a wireless printer or get a commercial program. Let's close this discussion and give it up for awhile? Thanks again, Chasaroo
Chasaroo
Mar 10, 2022Tutor
Just to print a file I've done on my laptop that can be jip drived to my desktop doesn't seem worth all the hastle. If this were a business and I were several floors away from the server, it might be worth the trouble and extra cost? Thanks Charlie
Mar 10, 2022Guru - Experienced User
Up to you to see if it's cost effective to you?
