Ericc0354's avatar
Ericc0354
Nighthawk R6700v3 and 3700 extender
A few days ago I noted an update to the firmware was available for my Netgear Nighthawk R6700v3 router. Using the Nighthawk app I executed the update and it proceeded successfully. The router came b...
  • plemans's avatar
    Nov 25, 2020
    try factory resetting the extender and reinstall it.
    Push and hold reset for 7-15 seconds while its powered on. then follow the install.
    If you check the attached devices page for the router, it should have the IP address for the extender. Maybe it changed.
