higginr
Jul 08, 2022Aspirant
Nighthawk R6700v3 and ATT 1000 Fiber
Has anyone had any luck getting a Nighthawk R6700v3 to work successfully with an ATT BGW320-505 and their 1 gig service? The download speeds drop to around 600Mbps download on the Nighthawks when me...
Kitsap
Jul 08, 2022Master
Has your R6700v3 been connected to a previous ONT, modem, or gateway?
If yes, the first thing you need to do is a firmware default reset on the router and go through the setup process from scratch. In that process be sure to leave QOS, access control, traffic monitoring, and parental controls disabled.
