ita47
Jun 17, 2022Follower
Nighthawk R6700v3 can it be connected to a Verizon Orbic Speed Hot Spot?
As the description states, I have a Netgear Nighthawk AC1750 R6700v3 router. I just received a new Verizon Orbic Speed hotspot from my employer which will be my only source of internet. Is there any ...
Jun 17, 2022Guru - Experienced User
The R series router requires a RJ45 LAN cable connection with a host modem or gateway router. If the hot spot doesn't have this, then there isn't a way to connect the NG router to the hotspot.
Something to ask the Mfr of this hot spot about for additional help and information regarding there product.
