duggu19
Jan 23, 2023Follower
Nighthawk R6700V3 Expressvpn firmware
So i wanted to try out the Expressvpn firmware on my R6700V3 to see if it would work for my setup. Turns out it doesn't now it won't let me reinstall the Netgear firmware. Expressvpn customer service...
michaelkenward
Jan 23, 2023Guru - Experienced User
Unfortunately, Netgear doesn't support third party firmware. You really need to ask the people who write it.
If you installed firmware on a device that does not claim to support it, you are a bit stuck.
The only option that comes to mind is TFTP.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
