UsualNoise
Sep 20, 2022Aspirant
Nighthawk R6700v3 maximum wired speed less than cable modem
I've seen several similar threads stating that a firmware issue exists that prevents reaching maximum available speeds, so let me know if there is anything I can do here. I have the current firmw...
Sep 20, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Try a factory reset and walk thru the setup wizard. Be sure to NOT enabled Armor, Access Controls, Circle, QOS or Traffic Meter.
UsualNoise
Thanks for responding!
Modem is my own, Arris Surfboard SB-8200. I'm 99% sure the cord is not the problem as I only use Cat 5e or better, but I'll swap in the cord I got 220 Mbps on my laptop just in case. Otherwise factory reset will be the next step.
- FURRYe38Sep 20, 2022Guru - Experienced User
đ
- UsualNoiseSep 24, 2022Aspirant
Just wanted to follow up - the factory reset fixed the problem. Kind of a pain to have to do that, but I guess if it works...
Too bad it doesn't just automatically fix itself after a normal reboot. Oh well, just wanted to post my results, my speeds are now matching when bypassing the router and when using a LAN port. Thanks all.
- michaelkenwardSep 25, 2022Guru - Experienced User
It does normally.
A reset isn't needed most of the time. A reboot usually works.
One thing you can try is to save the configuration before you update the firmware. Then if you have issues after an update you can reset the device and reload the saved settings..
This can revive the problem you had before the reset, but it doesn't always. If the issue resurfaces, then you just have to reset again.
In any case, you should always have a backup that you can reload for whatever reason.
