JoeShmoe3453
Feb 02, 2022Aspirant
Nighthawk R6700v3 poor wifi speeds
I currently have a fiber connection from at&t and use their modem/router with the wifi disabled as it is in the far back side of the house. I then have the nighthawk in access point mode in the middl...
JoeShmoe3453
"are you using smart connect?"
No smart connect is off and both channels get the same slow speed.
Feb 03, 2022Guru - Experienced User
You have the r6700 in access point modem?
What speeds do you get hardwired into it?
- JoeShmoe3453Feb 03, 2022Aspirant
Yes the r6700 is in access point mode and when hardwired into it I get the full 700-900 up and down speeds to be expected. Te problm only sems to be with the wifi.
- plemansFeb 04, 2022Guru - Experienced User
Try factory resetting the R6700.
during the reinstall, set it up in router mode. But go into the ATT device and put the netgears IP address into its DMZ.
- JoeShmoe3453Feb 04, 2022Aspirant
Factory reset and set up the router in normal router mode. Added the ip to the at&t's DMZ no chnage. Since I recently switched to at&t I still have my mediacom fiber (1000down-50up) but wifi speeds were still the same using a netgear cm1000 modem. eithernet conection remains fine for both netorks. And yes the router was haveing the wifi problem before I switch to at&t.
