Yasshak
Dec 31, 2022Aspirant
NightHawk r6700v3 Slow wired speed.
To start this off my setup is Astound Broadband -> Netgear CM1000v2 -> Netgear r6700v3 -> Monoprice Flexboot Cat6 Ethernet cable -> lenovo gaming 3i laptop. I am currently on Firmware V1.0.4.1...
Yasshak
Would auto detect be fine for IPV6?
Kitsap
Dec 31, 2022Master
Yasshak wrote:Would auto detect be fine for IPV6?
Yes as a first option. If no change, then pass through.
You may have to go with the default reset as previously recommended.
- YasshakJan 01, 2023Aspirant
There was very minimum change so I hard reset my router and turned on pass through again. Even with this I am getting 410-450 mbps. I do not have Upstream or downstream QOS on, the only setting I have changed in my settings is the IPV6 which I enabled and put as Pass Through.
- KitsapJan 01, 2023Master
Yasshak wrote:There was very minimum change so I hard reset my router and turned on pass through again. Even with this I am getting 410-450 mbps. I do not have Upstream or downstream QOS on, the only setting I have changed in my settings is the IPV6 which I enabled and put as Pass Through.
Please confirm specifically what you mean by "hard reset". A firmware default reset means you have to have the router power on and press and hold the recessed reset button on the backside for ten to fifteen seconds until the front indicators start to blink. Release the reset button and let the router boot. When this is completed, you have to reconfigure you router from scratch. This includes GUI passwords, SSID's, Wi-Fi passwords and etc.
The startup sequence of the devices is important. Power down your modem by disconnecting the adapter cord and disconnect the Ethernet cable to your modem. Power down your modem and disconnect the adapter cord.
Power up your modem and give it plenty of time to boot and stabilize. One of the last indicators to come on should be your internet. Since there is no Ethernet connected, the link indicator should be dark.
Connect your router to the modem with the Ethernet cord and power up your router. Give it plenty of time to boot and stabilize. One of the last indicators to come on should be your internet access.
When you do your throughput testing, recommend your install and use the native operating system application from Ookla. This removes a web browser from the test.
- YasshakJan 01, 2023AspirantI see, I had only done a firmware default reset I didn’t change anything with my modem because it was giving me 940+ so I had assumed it wasn’t the problem. I had still turned it off till my router was on completely and removed all Ethernet cables from the router. I will come back roughly 5am pst tmr when I firmware default reset my router again.
