Yasshak
Dec 31, 2022Aspirant
NightHawk r6700v3 Slow wired speed.
To start this off my setup is Astound Broadband -> Netgear CM1000v2 -> Netgear r6700v3 -> Monoprice Flexboot Cat6 Ethernet cable -> lenovo gaming 3i laptop. I am currently on Firmware V1.0.4.1...
Jan 07, 2023Guru - Experienced User
You have Errors and Criticals in the Event log that the ISP needs to review and resolve.
You have lots of Correct and Un-Correctables that should be mostly zero...
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Yasshak
Jan 07, 2023Aspirant
Should I call my isp to bring a repair man or not? If not what would I say to them during the call?
