ArchTux
Nov 21, 2022Aspirant
[Nighthawk R6700v3] Slower bandwidth than when directly connected on the "bridge" router
Hello, I have a router as bridge and then my Nighthawk router. When I directly plug my computer on the first router (and remove the bridge configuration), I get the 400 mbit/s as advertised by my...
- Nov 21, 2022
2 things to try.
1. I've seen to many devices not run properly in bridge mode. Leave the ISP's device in router mode and disable its wifi. Then either just run the netgear as is (it'll be in a double nat) or put it in access point mode (fixes the double nat). Then try it.
2. there's been a few reports of slow downs on that firmware. You can try downgrading the firmware a version or 2 (factory reset after changing firmwares)
Nov 21, 2022Guru - Experienced User
So we need better description/diagram.
1. what is the other router?
lay it out exactly how it is. For example, if you read my signature in my posts, it goes over how I have my network setup. Use something like that and not "on the first router". Be specific. Say My tplink **** is the primary router. I have the **** setup as a wireless bridge.
Is it actually setup as wireless bridge or in access point mode? Different manufacturer's mean different things by bridge. Some mean a wireless bridge where it doesn't rebroadcast, some mean its a wireless extender, some use bridge for access point mode. So be specific with the setup and how you are actually configuring it.
ArchTux
Hi, thanks for the help.
My ISP in Belgium is VOO and I have this routeur "Technicolor TC7210.V" (found here in French https://assistance.voo.be/fr/support/internet/installation-et-activation/trouver-le-modele-de-votre-modem-voo.html)
In this router web interface, if I select the bridge mode (other mode are IPv4, IPv6 or both IPv4/IPv6), I can't configure anything else other than the WiFi which is currently disabled for 2.4GHz and 5GHz since it is managed by my NightHawk.
So basically, I have done the following test.
No bridge, direct access to ISP router, Nighthawk powered off
Technicolor TC7210.V (IPv4 mode, disabled wifi) -> Netgear Switch GS308v3 -> Desktop computer via RJ45 => 400 Mbit/s down, 20 Mbit/s up
Bridge mode, going through Nighthawk R6700v3
Technicolor TC7210.V (Bridge, disabled wifi) -> Nighthawk R6700v3 -> Netgear Switch GS308v3 (enabled wifi in 2.4Ghz and 5Ghz, DHCP server on, DNS via pihole plugged on the switch but I also tried with direct DNS 1.1.1.1 from computer) -> Desktop computer via RJ45 => ~200 Mbit/s down, 20Mbit/s up
The firmware version of the R6700v3 is V1.0.4.128_10.0.104. The second setup (with the technicolor in bridge mode) worked before with speed of 400Mbit/s but some config changed during an update maybe and then I got this halved download speed issue.
Would you have any idea on the config I should have a look at in the Netgear R6700v3 interface?
Thanks a lot.
- plemansNov 21, 2022Guru - Experienced User
2 things to try.
- ArchTuxNov 22, 2022Aspirant
Hey, what a mess.
I guess I won't upgrade the firmware again when I have something that works.
I have now done the setup you suggested and it works.
I had to factory reset both routers, I am now directly connected via cable to my ISP router and I have 400 mbit/s.
I had to configure the nighthawk router with the iOS nighthawk app and I have less option than directly on the web interface via routerlogin. I remember that I had to enable an option to have a faster wifi but I don't have that option on the iOS app so I only have 200 mbit/s via 5g wifi. I'll try to find a way to access the web app once again.
I am not sure how my nighthawk router is now configured since everything was done via the app, is it access point automatically?
Thanks again for your help.
Okay, so I plugged my computer directly on the nighthawk and I could access the routerlogin.net interface. Without doing that, I could not access it, the only web page I could get is the one to recover the password (tried wifi).
Anyway, I changed the setup of the nighthawk to be an access point.
Thanks.
