Zenblak
Jan 04, 2021Aspirant
Nighthawk R6700v3 Speed Issues
I bought a Nighthawk R6700v3 last summer and I have not been able to get the speeds that I am paying for. Currently I am paying for 1Gb download from Cox using a Modem/router device that they su...
JayX
Jul 26, 2021Initiate
It's the firmware, The current firmware throttles your speeds to less than 200mbps. I'm not sure why Netgear hasn't addressed this issue. Personally I think it's garbage that they aren't doing Sh!t about it.... I had to revert back the a previous firmware to get my speeds back to the 1gig that I have.
Decreet
Nov 24, 2021Aspirant
I have the same problem. What firmware did you downgrade from? I need to do the same.
- FURRYe38Nov 24, 2021Guru - Experienced User
What Fw version are you using?
Since the OP first posted this, they were on v106.
I see v118 and v120 thats most corrent:
https://www.netgear.com/support/product/R6700v3#download
If v106, try v102 or something prior to v106.
- JayXNov 26, 2021Initiate
I downgraded to V1.0.3.66_10.0.50
It's been a couple of months since I last checked my speeds, as long as I'm getting 700 and up I'm okay with that. I'm just irritated when I upgraded the firmware that it went sub 200mbps. Right now I don't trust the netgear firmware and I'm looking for other router options. I think its best for my situation as I work from home and need the bandwidth to do work.
